1 - 10 of 10 Posts
Something different than the usual.
The car was bought from Roy Hommes in the Mustang workshop in the Uk.
Mustang Workshop | Servicing, upgrades & award winning concourse restorations
The shell had previously been restored in holland by a company called barts (Suppose ta be 1 of the top 5 restoration companys in the world)
bartholland.com
I have since been on to them 2 try and get pics and info on it before it was painted but as i was not da customer that got it done they will tell me nothing.(Go down through da bart link and u will c some pics of it been restored)16th row down.
It was then finished and re-assembled by roy in da mustang workshop.I have folders full of invoices and a list of every part that was put into it during the restoration process.
I got the car in April 2007, and at that time the only part that had not been overhauled at that time was the engine.
So i decided to finish the whole project off once and for all, so i made the decision to install a brand new crate engine that you could just buy of many companies in the states.
Chevy Crate Engines, Ford Crate Engines, Muscle Car Engines, Performance Engines, Motors
So enough of all the rambling see pics and spec below.
Engine spec;
Small block 5.8L v8 engine
350 bhp
Precision machined 351w series block (blue)
Cast iron precision ground micro polished crankshaft
Tri metal clevite 77 rod and main bearings
I-beam connecting rods with ARP hardened rod bolts
High performance Speed Pro flat top pistons
Hand filled performance rings to match
3 piece true double roller timing set
(16) high rev lifters (anti-pump up)
Remanufactured cast iron cylinder heads
Chrome moly push rods
(16) steel rocker arms
Melling high volume oil pump
Chrome front sump oil pan and dip stick
Edelbrock performer series intake manifold
Chrome thermostat housing to match intake
Edelbrock carberator W/electric choke
MSD pro-billet distribuator
MSD blaster II coil
Custom fit taylor 8mm ignition wires (yellow)
Fuel pump with inline filter
Hi-flow water pump
Tall chrome valve covers with baffles
Engine works performance balancer
Fel pro performance gaskets
The engine has a march performance
Alt, & PS Serpentine Kit on it also
(which consists of 6 chrome belt wheels for appearance)
dual exit exhaut system
Chassis
American racing torque thruster II rims
with bf goodridge tires
15"x8" size
4 x koni shocks
Interior
Custom made full leather bucket
Seats (made in barts of holland)
Rear seat made to match.
Leather internal panels with wood-grain look panels
All origanal clocks and gauges.
Exterior
Full respray in gold
Front and rear chrome coated bumpers
Rear window screen louver
Rear spoiler
Wing decals
Mustang grill decal
Aftermath bonnet
absolutely stunning, my dad had a boss 302 such road presence :bowdown1::cool:
Lovely car, you must be chuffed with it.
I have some lightweight Mustang wheels sitting in my shed, not used them in 30 years if they would be of any interest to you?
Hugh
Discussion Starter · #10 ·
Hugh
Thats sound mate ill keep it in mind.
I put the existing wheels on it when i got it in 2007 and there still even on there first set of tyres. Doesn't get a whole lot of use with the shit Irish weather
1 - 10 of 10 Posts
