Hello,
My name is Antony I live in France, I'm 21 years old.
I currently have a UKSpec vin number: JN1GAPR33U0000138
I have had it since May 2020. It was bought from HJA in 2009 before being imported to France.
Engine and transmission was rebuild by RB Motorpsort in 2008
She made 594 WHP and 624 Nm at 1.4B on E85
There is the current spec:
Engine (10000km)
Block and head machined.
Bore increased to 2.7ltr
New OEM Nissan crankshaft
TOMEI forged con rods
OS Giken forged pistons 86.5mm
NISMO Main and bottom end bearings
Crankshaft seals
Nissan crank gear
Dynamically balanced crank assembly
Head stripped and new valve seals and rocker washers fitted
N1 oil pump
N1 water pump
TOMEI Sump baffle
TOMEI 1.5mm head gasket
HKS timing belt
HKS Cam gears
HKS step 1 camshafts
Induction
HKS power flow filters
NISMO AFM’s
HKS Complete hard pipe kit (powder coated black to match block and cylinder head covers)
Fuel system
SARD 800cc injectors
TOMEI fuel rail
Tomei fuel presure regulator type L
DASH-6 fuel lines with proper connectors
Large in tank fuel pump (not sure which make)
Turbos
New Garret GT2860-5 x 2 with new actuators
HKS Balance pipes
Exhaust
HKS Exhaust manifold
MINE’S Down pipe
TRUST power extreme exhaust
Decat pipe.
Cooling
APEXI race radiator and SAMCO hoses
APEXI race intercooler
25 row oil cooler
Transmission
Gear box overhauled less than 15000 km ago, new gears, syncros and input shaft.
OS Giken twin plate clutch
OS Giken release bearing
NISMO or HKS short shifter/quick shifter
NISMO gear stick
Suspension
TEIN Mono flex with EDFC in car controller
Engine Management
APEXI Power FC
APEXI Hand commander
APEXI Boost controller
R35 Coil pack conversion from PRP
Interior
BNR34 front seats
NISMO Centre and dashboard gauges.
OEM optional carbon look dash surround
365B steering wheels + nismo old logo horn button
400R Floor mats
Wheels
VOLKS CE28N’s 18x9.5J OF +15 repainted in Black fitted with 265x35x18 Toyo R888R
Brakes
Endless disc + MX72 brake pads front and rear.
Wheel Tire Land vehicle Car Vehicle
Wheel Tire Car Vehicle Automotive tire
Car Vehicle Gear shift Speedometer Motor vehicle
Hood Car Motor vehicle Vehicle Automotive design
Car Vehicle Steering part Car seat cover Motor vehicle
Photos in 2009 taken by HJA,
There is a video on YouTube :
Unfortunately the previous owner had repainted the rims green, had thrown away the original seats and put on bucket seats.
Vehicle Automotive tire Hood Car Automotive design
So I decided to put r34 gtr front seats and repaint the rims in gloss black. Put on 365B steering wheels.
Wheel Tire Car Vehicle Hood
Sky Car Wheel Vehicle Tire
Sky Cloud Car Vehicle Grille
Wheel Tire Cloud Sky Car
The BNR34 Vspec is also mine, bought it in april.
I am in the process of buying a lot of parts to do a complete restoration.
Sorry for my english.
Thanks for reading :)
Antony
You have some very nice GT-R's there Antony, Thanks for sharing and letting Us all know another UKDM BCNR33 is alive and well mate!:cool:
