hi
i have hks 2871-10 turbos, fcon-pro, and a greddy profec b boostcontroller on my gtr34. normally i drive 1.9 bar in high boost.
the boost always goes up to 1,9 bar but then lowers to 1,4-1,6 bar.
sometimes it stays on 1,9, soemtimes not. it happens more in higher gears.
my actuators are from HKS. i know my 70mm intercooler is rubbish and the air temp goes over 50 degrees in higer gears but this cant be the reason. it also happesn in 2nd gear sometimes.
i think it could be that the hks actuators are not good anymore or it might be because i dont have a hard pipe kit. the rubber between the turbos and the air filters are really weak, i can push them together really easy with two fingers. if they suck together the boost breaks down i guess?
any idea what it could be? i dont want to buy an expensive hard pipe kit or new actuators without solving the problem.
weak rubber pipe is marked yellow
