sat at thor...
thought i would share my dyno graph with you all..
here,s the results..
engine spec...
hks 25/30.
hks elbows.
power fc d-jetro ecu.
tomei fuel pump.
720cc injectors.
jun 264/272 cams 9.15mm lift.
n1 oil/water pumps.
acl bearings.
tomei sump baffle.
tomei 1.2mm head gasket.
tomei adj cam pulleys.
greddy cam belt.
cp forged pistons.
exedy twin plate.
car made 520bhp @ the hubs @ 1.2 bar..
fuelling is 11.5.1 @ 8000rpm
p.s blue line is the old dyno dynamics map. red line dynopack.
engine spec...
hks 25/30.
hks elbows.
tomei fuel pump.
720cc injectors.
n1 oil/water pumps.
acl bearings.
tomei sump baffle.
greddy cam belt.
cp forged pistons.
exedy twin plate.
