Hi guys my engine should be going in tomorrow just wanted to know if there are any tips you guys can give me about things that should be done and looked at before and after the start up, I know the HI-CAS system has to be reset with the wheels straightened out, run the oil around the engine beforehand (leave spark plugs out or disconnect the coil pack) and bleed air out of bleed screw for cooling system.
Any other suggestions.......
