more....
:thumbsup: ^^^
Time for another weekly update on progress with Matt's 33 build.
So more rust located in the front drivers arch/body area.
You can see once the underseal is cleaned back where the panels are suffering.
Only thing for it is to cut out and repair.
Every bit of rust removed as with any internal rust!
Cut out, the level of interior rust is now evident.
Brand new metal panel fabricated and welded in, cleaned up and protected.
Much better!!!!
We could also see once cleaned back the front lower cross member where the radiator mounts was starting to bulge from rust between the layers.
You can also see the blistering on the surface in the pic above.
From another angle you can see the problem better between the metal layers.
With the panel removed you can see how the rust had started to spread.
All rust cleaned up and treated before the new panel goes in to replace the rusted one.
Perfect again!
Another area effected by rust was the area where the steel gts front wings had rusted through
and were touching the front of the sills.
Out you come!
clean up of the interior of the sill was much easier with this access too!
Other side wasn't as bad.
But still needed attention.
Now for the long and messy job of removing all of the factory underseal to see what's hiding below.
At this point we start to really be able to judge the condition of the underside.
One of the worse parts to suffer rust on an R33
(apart from the strut tops) Is the rear 'L' Bracket areas, where the rear subframe support braces mount.
Matt's were quite bad, but fortunately because the car hadn't been plastered with underseal it had been allowed to dry out so was quite localised.
Again cut out the bad stuff to investigate the extent of the rust.
Clean back all of the surface rust.
Marked off the mounting points so we can line up the captive nut when we're replacing the panel.
Cut out to make proper repairs.
The other side was the same story alas, (usually the case).
As you can see on the whole Matt's 33 is super solid!:bowdown1:
New metal being fabricated by Jay.
Old panel was cut out, media blasted back to clean metal, repaired and then reinstated.
With the new fab'd outer panel in place shes as solid as new! No more subframe bracing flex here.
