The rear lights went on the blink.. So my first thought was where is the fuse,, looked in the handbook for the car and i could not see where it states the fuse location for rear light.. Checked the fuses inside the car and under the bonnet next to the battery.. There are not located at these positions,, there is an upright black box next to the battery with a cover that i found impossible to remove until you remove the battery.. Now the fellow who designed this should be taken out and shot,,, i located the problem that caused the fuse to blow.. Also this fuse is a micro fuse which most folks wont have sitting in the toolbox... Hope this info is a help
