1 - 20 of 27 Posts
hi all just thought I'd post a quick vis of my new motor
no its not working i f##### the bb code up:chairshot:lamer:
Looks fast!
Gotta feel fast!
Nice, very nice, spec please, good to see a video of a MGT racing car spanking the quarter mile! Got a vid to show the lads what the local tuner can do now. :thumbsup:
Discussion Starter · #10 ·
here's most of the engine spec cant be asked to write all of the cars spec down as i would be here ages lol. at the mo its in bits anyway as i had bit of a oil issue so its being rebuilt with a dry sump
hks 2.6 full counter crank
n1 pistons
n1 water pump
trust con-rods
" sump extension
tomei con-rod blots
" head bolts
" bottom end bolts
" cam stud kit
" pro cams
" type c valve springs
" buckets
modified block
hks oil pump
Infinity throttle-body
1000 cc injector
Trust fuel rail
HKS GT twin entry Inter-cooler
TRUST 22 row oil cooler
BLITZ Aluminum radiator
Low temp thermostat
hks 4inch exhaust
Original exhaust manifolds
modified GT2835R turbos
hahahaha
i remember seeing this car in the flesh :p
sounded well impresive on the dyno, loads of boost and 10.000 revs sounded very scary.
look at that happy face in the back ground hahaha
dry sump? oh my, hehehe, cant wait to see it finished
good luck dude, catchya soon
simon
looks sweet nice smooth run ,what gearbox it running?
Discussion Starter · #14 ·
hahahaha
simon
hey simon hows things?
I'm running a OS 1-5 gear set with the uprated input shaft and and a hks triple also running Cusco front and rear lsd's
ok thanks for that ,whos doin the dry sump kit
Discussion Starter · #18 ·
still looking into it
whats the reason for a dry sump? Would an accusump system not work for you?
well with a trust sump I still have oil surge, and I've seen enough high power cars to know that if you do not want to worry about oil problems then a dry sump is the way forward as there is just so many benefits in having it.
As for accusump think there OK to use as a pre oilier but that's about it.
1 - 20 of 27 Posts
