1 - 18 of 18 Posts
Well my R32 gtr looks like its away today and i have just bought myself a new toy.
Makes sense for me to buy something that has had 90% of the work completed as i have a baby on the way in March and the R32 still needed alot of work.
So the spec list so far a real credit to the previous owner who has done all the work himself
body and chassis:
- R33 type m shell
- custom roll cage painted white
- painted same as outside of car
- custom aluminium door panels with carbon wrap and door pulls
- rear parcel shelf / bulkhead removed
- omp steering wheel and boss kit
- bride low max bucket seats
- takata harnesses
- willwood hydraulic handbrake
- digital pro sport Evo series water temp/ oil temp/ oil pressure / boost gauges
- complete hicas lockout kit
- MHD fully adjustable coilovers
- adjustable rear camber arms
- front adjustable control arms
- front strut brace
- rear strut brace
- complete heat shield and sound deadening removal throughout
- stripped down custom interior loom
- custom dashboard , air con system and boxes removed
- welded gtst diff
- 2 peice split rays engineering wheels 9.5j all round
- 15mm hubcentric bolt on spacer all round
- EBC yellow stuff pads all round
- reconditioned Nissan calipers
- complete new brake lines throughout including copper lines
- gloss black underseal to all arches, front and rear subframe and arms
- relocated battery and fuse box to boot
- GTR style front grill
- hid kit 8000k
- rack spacers
- s14 non hicas steering rack
- custom powersteering lines
- brand new rack ends
- powersteering cooler front mounted
engine and drivetrain:
-1JZ non vvti engine removed from a soarer twin turbo. 180psi on all 6 cylinders
- front mounted sump from an import jz
- r154 gearbox
- shock proof gearbox oil
- custom made and balanced prop
- custom engine and gearbox mounts
- custom front subframe , strengthened
- competition clutch stage 5 extreme sprung clutch kit
- competition clutch lightweight racing flywheel
- custom colour painted engine bay and enginecovers
- painted engine block and ancilaries
- front mounted oil cooler and relocation kit
- japspeed aluminium radiator
- twin electric fan and aluminium air trap shroud
- greddy style inlet plenum
- 80mm throttle body
- q45 tps sensor
- mild steel top mount manifold
- custom 3" turbo back exhaust
- blitz nur spec r system
- garret gt3582r roller bearing turbo
- ceramic coated exhaust manifold / turbo housing
- ceramic wrapped downpipe
- tial 44mm external wastegate
- custom screamer pipe ceramic wrapped
- front mount intercooler
- blitz sus air filter
- 4" filter pipe
- custom an12 twin breather system to front mounted catch tank and breather filter
- braided turbo oil and water lines, heat wrapped for protection
- genuine Toyota cam belt kit , including hydraulic tensioners
- genuine termostat
- new fan belt
- genuine Toyota rocker cover / thermostat / exhaust / inlet / water housing gaskets
fueling system :
- denso 850cc injectors
- high flow fuel rail
- intank Walbro gtx400 fuel pump 395lph
- malpassi adjustable fuel pressure regulator with gauge
- fully braided fuel lines from tank to the fuel rail
- an fitting for easy removal
Fuel system currently at 50% duty
ecu / electronics :
- VEMS standalone management system
- VEMS electronic boost controller with adjustable dial
- runs launch control
- custom engine loom built from scratch, removing all unused wires
- new trigger wheel to suit Ecu
- brand new audi TT coilpack conversion
- NGK irridium grade 8 plugs
- dash mounted eleictric fan control switches
- dash mounted launch control switch
Plans
upgrade the Brakes i have a set of K sports sitting for the front and also going to upgrade the rears to likely gtr spec anyway.
Fix the power steering leak get new pipes made up there seems to be a progressive leak at the return line
Bodywork- Gtr bumper clean up some rust areas underneath and also above the rear screen and a good machine polish.
Oh and a new set of wheels the ones that are on it look a little lost even with the spacers. Gutted it would need alot of work to get my Volks GT-C's on so might look for a set will weaker offset.
A few pics from the previous owner and will get a few once its back home in my garage next week
Always nice to see random conversions. Looks a good job.
Have you never suffered from heat soak issues from the turbo to BMC?
Greg
Looks awesome, saw this for sale a while back - very nice car indeed.
Will you be drifting it or just regular track stuff?
Discussion Starter #6
Its going to be an out and out drift car for Driftland up here in Scotland maybe a few days up on the quarter mile but thats it
Discussion Starter #7
Greg
Hi Greg,
Boy has ran it for 6 months with no issues i have only just got it so we will see how it goes. I like different :)
If it's more road and drift then you won't probably have any issues, but a track day I reckon you'll feel the heat soak. But looks good. :thumbsup:
Greg
Definitely a great project. Sometimes it's nice to have a change and mix two together
Sounds well wen on boost and goes well too you will def enjoy this I think jay is now wanting a BMW can u believe it lol
Discussion Starter #14
Yeah he says he wants to grow up :D A week is a long wait for me to get home and have a run in it. But hey its working away that has made me the money to buy it. Just a shame we are well and truly into winter :( Gives me time to put my own improvment on the car the Brakes and new wheels
Blasphemy! But it looks great, so **** it, I like it! :chuckle:
1 - 18 of 18 Posts
