601 - 620 of 852 Posts
Discussion Starter #603
Why 2 wastegates?
As in why a manifold that required 2?
As has bee mentioned previously on various threads on here and SAU, boost control is more effective with 2 smaller gate's rather than a larger single.
Besides, 2 are more expensive......:chuckle:
TT
Discussion Starter #605
It's also a twin scroll manifold, hard to vent excess pressure from 3 runners which aren't connected to the other 3 using one valve!
Yes, that as well....
:chuckle:
And because 2 are more expensive.... :chuckle:
TT
Discussion Starter #606
Well, managed to find the right fitting by a bit of guesstimation.......
Rather chuffed with myself as I don't have an imperial thread checker and usually end up going through a few fittings before getting the right one...:chuckle:
Having a dilemma about exhaust manifolds but need to make a decision soon and get things moving.....
TT
Discussion Starter #607 (Edited)
So, more going's on today...
Drilled and tapped the water jacket thingy under the throttle bodies....
Took it out to an M12 and used a grub screw I had lying about. I've no need for it so best of getting plugged!!
In a drilling and tapping frenzy, I did the same to the nipple that used to grace the rad top hose elbow......
I've ordered an M12 - AN6 fitting and will use braided hose between here and turbo water outlet.
THEN, I made up a little blanking plate for the rear turbo oil drain hole as I wont be using it any more...
Noticed that my block is an N1. Had a major suspicion about it when I bought the car and this categorically proves it. Certainly looks kosher to me chuckle: :chuckle:
In a fit of nonsense, I changed the water fitting to a stainless one over the aluminium one. So, water and oil feeds and rear turbo drain blank plate....
So that's all the water/oil port stuff done in prep for the hoses and fittings. Just need to decide on a bleedin' manifold!!!
TT
TT
Your not going to do an R32Combat and use copper radiator pipes are you? :chuckle:
Discussion Starter #610
No. Is just the same but instead of the dual outlet fitting I have used a single barbed fitting.
After all, it's a car....not a central heating install :chuckle::chuckle:
TT
Was just looking at post 537, I also want to remove all the crap under the plenum, have you got pics of what exactly is required and what needs to be blanked off?
Discussion Starter #612 (Edited)
Suppose it depends on how far you want to take it with regards to your specific application.
I am using a single turbo and so the plenum side on mine looks thus....
Basically all gone, water and vac..... using the water/oil feeds from the other side of the block and the front water return here....
To which I have installed an AN-6 fitting.
Got myself a turbo pre-filter....
Which should provide a bit of extra filtration....
And, if that wasn't enough, I also managed to find an unused, secondhand (genuine) DEI T4 turbo blanket kit for a huge saving from new.....:)
Have decided on a Full-race exhaust manifold so will be placing an order imminently...
TT
Discussion Starter #613
Received these this morning.....
Am in the process of getting shipping quotes from Full Race for a manifold so should have that sorted V soon.....
TT
Discussion Starter #614
Despite me trying to have some resolve here I jumped in and bought Graham1987's Trust 264 9.7 cams :)
Full-Race manifold has a 4 week lead-time so getting these fitted will give me something meaningful to do in the intervening period :chuckle:
These should be a nice compliment to the GT4094 I reckon....
TT
Discussion Starter #617
So, placed my order today for a Full-Race T4 manifold with twin 44mm wastegate flanges and 2000deg ceramic coating.....
:thumbsup:
Can't wait to get it and the turbo on and plumbed in :D.....
TT
Discussion Starter #619
As invariably happens, I was sat the other day with money burning a hole in my pocket so ended up buying a pair of Bi-xenon lights....
Will remove std headlights and make up some carbon or GRP blanks. The near-side one will have a duct incorporated which will provide air to the monster K&N and both will have one of these lights embedded. Had thought about doing this for a while now so pushed the 'buy' button and stopped procrastinating....:)
TT
Discussion Starter #620
Well....... some rather large happenings in the world of Skyline!!...
First off, I received my Xenon lighting kit which, for the money, is frankly amazing!!. Secondly, picked up compressor housing from local welding shop after they fitted my self-made boss...
Did a sterling job as usual (they welded my Ti decat and plenum)!!!
However, there has been a rather large (temporary) change of direction......
This month I planned to buy the Syvecs S8 ECU as well as the Motes CAN keypad and UTC adapter which would have pretty much finished off the (current, pre-mapping) shopping list!. Unfortunately I was presented with an offer that was just too good to refuse and have ended up spending my ECU stash on a share of an aeroplane!!!..
It was just too good an offer to pass up and the GTR has had to suffer the consequences :bawling:. However, I will be saving up once more and the missus has agreed that the ECU money will come out of joint funds in the springtime rather than my own car/hobby stash so good news there...
So, time to contemplate with the GTR until spring I reckon......:rolleyes:
TT
