721 - 740 of 852 Posts
Discussion Starter #721 (Edited)
After a bit of fettling of the bells after discovering my centre bore measurements were off (I hadn't noticed that there was a small step at the hub end) I got the rotor/bells and calipers on......
Might look a little small in diameter (310mm) but what they lack here they make up for in width (32mm). Plenty thermal mass to get rid of heat!!
Both sides done, now just need to make up some rear lines and bleed them.
Well pleased with the effort today....
TT
Just read this from the start to where you are now (quiet day at work ;-)...). Well done for having the patience to see this through and the imagination to not just use whatever is "cool" right now!
Iain
Discussion Starter #724
Iain
Hi Iain, thanks for the kind words!!
I try to be a little 'left field' when it comes to modifications and parts and tend not to follow the crowd. I find sheep often end up in kebab shops (metaphorically speaking!) :chuckle::chuckle:
Being Scottish, I tend to like a bargain and get more of a buzz from finding decent bargains than buying everything new....which I find a bit boring.!!
Anyway, thanks for taking the time to read all my mutterings and drivel :)
TT
  • Like
Reactions: anthonymcgrath
Discussion Starter #726
How have you found your new brakes then overall? Is that wider thickness helping?
Sent from my SM-G920W8 using Tapatalk
Car wont be mobile for another couple of months yet....I'll let you know!!
TT
Discussion Starter #727 (Edited)
Got on with the rear brakes again today and got then finished! Got some AN3 braided hose and ends the other day and made up some lines. Bled them earlier and all is good!!
Also made the decision to remove the cap screws securing the bell to the rotor and replace them with button head 10.9 HT bolts instead....
The low profile bolt heads will help with decreasing air resistance :)chuckle:)...
Also finished wiring the stock 4WD power feeds so just need to fire it up and see what happens..
So, now all that is left is to get the dampers rebuilt, get them back on and we're ready for mapping........
Excited!!
TT
  • Like
Reactions: FRRACER
Discussion Starter #730 (Edited)
After finding a local place that does anodising, I'm thinking that I might get the bells done in order to provide a bit of corrosion resistance....getting quotes.
Anyway...
After buying a myriad of different hoses and joiners I have finally managed to find a workable solution for the cold-side boost plumbing using the minimum amount of joins and which has the least nasty bends...
Quite pleased with that.... Just need to get some proper sized hose clamps and we're sorted. Just leaves the air filter....
I may have gone a bit big (largest cylindrical filter in the K&N catalogue!) on the filter, given the boost plumbing is now in place. I think I may have to cut more of the inner wing away and tuck it down behind the light. Won't be a massive issue.
On completion of this, all engine-related work will be complete!!
Really just leaves the damper rebuild and we'll be off for some mapping!!!
Excellent!!
TT
Discussion Starter #732 (Edited)
Got to work on the issue of the air filter assembly...
Cut away more of the lower inner wing to accommodate the, quite frankly...ENORMOUS, K&N filter...
Had some edge trim left over so added it to the edge to make it less hazardous to hands and filter :chuckle:.
Got a delivery of aluminium duct today so used it to connect turbo to filter...
Decided to go with braided lines for the wastegates so have ordered some PTFE hose and ends so it bloody better look/perform the part for the c£150 spend!!! :eek:
TT
  • Like
Reactions: Whitewheels
Discussion Starter #733 (Edited)
Got a bit of motor motivation today and painted the replica N1 lip that I modified (shortened to fit between catches)..
Decided that, rather than bugger about with double-sided tape and glue etc which is a bit hit-and-miss, I'd secure it with pop-rivets. I've added a couple of layers of FG to reinforce the areas that the rivets will grip to in the hope it won't break :chuckle:
No comments about the dust please!! :chuckle:
TT
Just finished reading the entire thread, just, wow, dude!
So many good ideas / solutions, mind if I borrow a few? :D
Go on, go on, subscribed!
Cheers,
Chris
Discussion Starter #736 (Edited)
Thanks for the kind words....
By all means borrow the ideas. However I insist you have a LARGE sticker made up and prominently displayed saying "This car contains parts inspired by tarmac terror"...
:chuckle: :chuckle:
TT
  • Like
Reactions: Austrian GTR
:chuckle: :chuckle:
TT
Guess I have to get this sticker made up too, as I borrowed the idea with the fuel cooler :chuckle: :chuckle:
Cheers,
Leo
Discussion Starter #738
Cheers,
Leo
I think we're quits Leo seeing as I run a similar PAS cooling setup to yours :chuckle:
:thumbsup:
TT
  • Like
Discussion Starter #739
Got some AN3 fittings and hose and made up some boost control plumbing to wastegates and boost controller....
Just an example. Had some DEI thermal sheath sitting doing nothing so used that to help keep heat under control :)
Somewhere along the line I managed to get my requirements wrong, therefore I am 2 fittings and a tee-piece short!! These will be getting ordered ASAP and work completed.
On another note, I sent my 2 front dampers away to AST for a rebuild so it's only the rear's to sort out when I get paid and then the car is ready for mapping.
Having thought about it, it's daft to get the mapping done now as trackdays get sparse over winter and I'm not keen about debuting the car at a winter session. Therefore, I will mothball the car until spring and get it mapped then.
TT
  • Like
