hi guys this is my skyline, basicaly bought it afew months ago, my dream gtr with all the bells and whistles....well that was until piston number 6 decided to die. I was told when i bought it it had N1 pistons and rods, with N1 oil and water pump.
So i decided to rebuild it and go to MGT-Racing in Nuneaton as i heard they had a very good reputation with skylines, when [email protected] MGT opened up the engine and inspected it, it turns out the engines bottom end was stock (car was 556bhp at fly) :nervous:
so i replaced the pistons and rods with PEC rods and Woosner pistons
ohhh shiney
also had a tomie baffled sump fitted :smokin:
i ran the engine in after the rebuild, next step was to remove the powerFC and nismo MAFs and replace them with a Link G4 ecu
i could not believe the results it made on the [email protected] with 450lbs torque at 1.45 bar, love it, its an absolute animal.
a big big BIG thank you to Mark and Garth @ MGT racing, top guys, ,top quality work, if theres any probs with it i know i can count on thoses guys to put it right, cant thank them enough,
Any way pics of the car
ENGINE.
GREDDY PROFEC B SPEC 2 BOOST CONTROLER
LINK G4 ECU
MGT -Racing ECU MAP 556BHP @ HUBS
HKS ACTUATOR KIT
GREDDY IRIDIUM SPARK PLUGS
SPITFIRE COIL PACKS
TWIN GT2860R TURBO CHARGERS
TOMEI TURBO ELBOWS
GREDDY DOWNPIPES
HKS TWIN MUSHROOM AIR FILTERS
ARC TITANIUM HOOD COOLING PANEL
ARC FRONT MOUNTED INTERCOOLER
GREDDY HARD PIPE KIT
BLITZ NUR-SPEC R EXHAUST
HKS EXHAUST GASKETS
TOMIE PRO CAMS 270 DEGREE IN & EX
TOMIE CAM PULLEY SET (ADJUSTABLE)
TOMIE VALVE LIFTER SET
TOMIE VALVE SPRINGS
TRUST CLEAR CAM COVER
COSWORTH 1.1MM HEAD GASKET
PEC CON RODS
WOOSNER PISTONS
GRADED BEARINGS
BALANCED CRANK
ARP BOLT SET
NISMO N1 WATER PUMP
NISMO N1 OIL PUMP
PROALLOY RADIATOR
TOMIE BIG SUMP
HKS TWIN ENTRY FUEL RAIL
SARD 720cc TURQUOISE INJECTORS
HKS FUEL PRESSURE REGULATORS
HKS FUEL PUMP
BRAIDED FUEL LINES
BRAIDED OIL LINES
ABBEY MOTORSPORT BREATHER KIT
SILKOLINE PRO S 10W-50 OIL
RSP ALUMINIUM OIL CATCH TANK
NISMO OIL FILLER CAP
GTR POLISHED FUSE BOX COVER
POLISHED ROCKER COVER
POLISHED PLENUM
TOMIE COIL PACK COVER
OS GIKEN FORGED GEAR SET
OS GIKEN TWIN PLATE CLUTCH
NISMO SHORT SHIFTER
REDLINE HEAVY SHOCKPROOF GEAR OIL
SUSPENSION
NISMO S-TUNE SUSPENSION
HKS KANSAI TWIN TUBE ALLOY STRUT BRACE
GT-R STD REAR STRUT BRACE
DO-LUCK REAR TENSION CAGE
DO-LUCK REAR CROSS BAR
TOMIE HICAS LOCK OUT KIT
WHEELS & BRAKES
WORKS VS-XX 3 PIECE SPLIT RIMS 18" BY 11" WIDE
PIRELLI P-ZERO 265/35 TYRES BRAND NEW
BREMBO BRAKES FRONT WITH GROVED DISCS
BREMBO REAR BRAKES
CUSCO MASTER CYLINDER SUPORT BRACKET
EXTERIOR
TOP SECRET FRONT BUMPER
JUN CARBOM BONNET
JUN SIDE SKIRTS
VEILSIDE REAR BUMPER
TEIN BONNET DAMPER KIT
NISMO CLEAR SIDE INDICATORS
NISMO CUSTOM MOUNTED CLEAR FRONT INDICATORS
XENON HEADLIGHTS
INTERIOR
PIONEER AVH-P4000 TOUCH SCREEN DVD
NISMO 11,000 RPM SPEEDOMETER CLUSTOR
DEFI LINK CONTROL UNIT
DEFI EXHAUST TEMP GAUGE
DEFI BOOST GAUGE
TRUST A PILLER GAUGE POD
TOAD AI-606 CAT 1 ALARM
PUSH BUTTON START
ohhh shiney
ENGINE.
LINK G4 ECU
HKS ACTUATOR KIT
SPITFIRE COIL PACKS
TOMEI TURBO ELBOWS
GREDDY DOWNPIPES
HKS EXHAUST GASKETS
TOMIE VALVE SPRINGS
PEC CON RODS
WOOSNER PISTONS
GRADED BEARINGS
BALANCED CRANK
ARP BOLT SET
NISMO N1 WATER PUMP
NISMO N1 OIL PUMP
PROALLOY RADIATOR
TOMIE BIG SUMP
HKS FUEL PUMP
BRAIDED FUEL LINES
BRAIDED OIL LINES
POLISHED PLENUM
NISMO SHORT SHIFTER
SUSPENSION
WHEELS & BRAKES
BREMBO REAR BRAKES
EXTERIOR
JUN CARBOM BONNET
JUN SIDE SKIRTS
XENON HEADLIGHTS
INTERIOR
DEFI BOOST GAUGE
PUSH BUTTON START
