1 - 10 of 10 Posts
Hi Guys
I have tried the search but couldn't find anything that answered my question.
I have fitted a blackvue power magic box along side a front and rear camera. I have wired it as other people have done, constant supply (room lamp) ignition on supply (lighter circuit) However as soon as I lock the car the unit loses power and parking mode doesn't work. Has anyone one else had an issue similar to this? Perhaps I should be using another constant supply fuse?
I don't think room lamp is a constant supply. I'm sure someone who has fitted can confirm. I'm running a power magic battery pro so only need a switched on when ignition on so it's a slightly different set up
Room lamp isn't permanent live, it goes to sleep after a while, we can install it for you properly if your near Birmingham
Discussion Starter #4
Thanks for your replies, unfortunately I am down in Cornwall so quite far away. Is there a permanent line in the inside fuseboard? Or would I have to find one at the main fuseboard?
1 - 10 of 10 Posts
