So whats the deal with the R34 N1 rear brake setup
From what i've researched, it has larger 322mm discs rather than the stock 300mm discs.
And this setup was standard from V-Spec II onwards.
My main questions are
1. I have seen people stating R34 "N1 Calipers". Are the calipers different? Because from what i can see they don't look different. It is still single piston?..
2. Due to the larger disc, is it that the caliper is different on the inside? If this is the case can you use an offset bracket to utilise the larger N1 disc?
3. I have heard that the same caliper and disc is used on the 350Z....is this true?
Thanks for all your help in advance
