Are you sure about that?Provides a higher flow rate so better cooling under load
yep :thumbsup:Are you sure about that?
That is right, Cavitation (Foaming of the water) can affect the engine cooling at high revs.Are you sure about that?
Looking at the design, I would say the Stock one flows more.
The N1 is supposed to flow better at high RPM's as the stock one suffers from cavitation at high speeds. ...............But that is something I read off the internet, so who knows if it is true.
