New Car Protection
"The Investment package"
Even new vehicles aren't detailed properly!
Believe it or not, in most cases, a new car's paintwork doesn't always come out of the forecourt perfect. So much so, it is a good idea to have your car detailed immediately after purchase. When buying a new car it is important to make sure it has the best start to ensure it stays like new. Your paintwork is decontaminated before applying sealant to ensure your car is protected from contaminants from everyday driving.
[We may require your vehicle for up to a maximum of 24 hours, but only in extreme circumstances.]
Cost: £120
£20 Extra for plus size vehicles.
Examples:
Vans: Ford Transit, VW Transporter, Mercedes Sprinter ect
Pickups: Nissan Navara, Toyota Hilux, Dodge Ram ect
4x4: Range Rover, Discovery, Mitsubishi Shogun ect
Vehicle rinsed using low pressure filtered water
Lower third sprayed with a non caustic citrus cleaner, and rinsed
Wheels, arches and door shuts cleaned by hand with a non caustic citrus degreaser
Wheels cleaned with a pH neutral wheel cleaner
Vehicle sprayed with a pH neutral snow foam, left to dwell and rinsed
Hand washed using a sheep wool mitt, with a pH neutral shampoo using 2 bucket method
Tar removed from vehicle
Hand dried using high quality, specialist, microfibre drying towels
Clay bar/clay sponge paintwork and glass to remove any contamination
Paintwork is inspected using a high Lumen light. Vehicle is then masked to protect trim, plastics and windscreen and then corrected using a single stage machine polish, removing as many swirl marks, micro marring, light scratches, holograms, and bird/water marks as possible.
Pre-wax cleanser applied to ensure bonding of protection layer
Vehicle wiped down with IPA (Isopropyl alcohol) solution to remove any contaminants or oils from the polishing stage
Dodojuice high Carnauba content wax or Dodojuice Supernatural hybrid wax applied to paintwork, and door shuts
Chrome/stainless steel polished including exhaust tips
Interior glass cleaned
Leather cleaned and fed if applicable
Exterior windows and mirrors cleaned
Layer of detailing spray applied
Tyres cleaned and tyre dressing applied (satin finish)
Final inspection to make sure your car meets our high standards
Cost: £120
Examples:
