1 - 10 of 10 Posts
having now found the virtues of gtr ownership i have now totally rebuilt my very 2wd gtr track car, miles etc were unknown as it came from japan but spec is now as follows
new n1 block
je 87mm forged pistons
new genuine rods as old ones had some wear up to 2 thou on each
complete set of new gen bearings
new n1 pump
tomei headgasket 1 mm
tomei inlet gaskets
tomei exhaust gaskets
2 brand new r34 n1 turbos
all new studs etc
n denso iridium plugs
massive fmic
all alloy 7 lt radiator
tein suspension
gtst rack with modified stops
all rebushed front to rear
ajautable camber arms
tein front tie arms
all rosejointed front uppers
at present running in for t drift battle at weekend but need some help guys
on a std ecu std injectors etc whats safe to run?
also high idle prob has returned cant get it down below 1500?
1 bar? or more?
also have a apexi power fc but isnt mapped yet as was awaiting injectors and pump
realistically im looking for 400 hp i dont need anymore its not a road car also very light with 2wd gearbox etc no hicas etc
ive never been messed about with so many so called speacialists in the uk who really havent a clue about engine building and general engineering esp in sizing bearings etc any help appreciated and see you all at the gt battle mark
Before i start to make my own rose jointed top arms for a GTS-t R33 do you happen to know if anything decent is commercially available please? Nice spec car. Rod Bell knows plenty about building a good RB26 or RB25 engine. Ian at Hiteq is extemely competent, so are others. I am doing my own, with advice from some of the above!
Peter said:
I think that I can help you there Chris, it's all very simple... :D
:rolleyes: In fairness I am so busy with race engine and chassis work I'd be a fool unto myself to try and take on any road car stuff at the moment, but come the end of the race season, who knows! I am confident you'll be able to oblige me if the time comes :smokin:
Chris Wilson said:
I'm not a paid up trade subscriber, so I can't tell people what a fantastic engine I built you.....
Everyone, it's a fookin stunning engine. Faultless, absolutely faultless. The sweetest revving thing you have ever heard.
Your very kind Charlie, thanks mate! If you are anyone else is interested I am taking pics of my own RB26 GTR engine build, which is going in my R33 GTS-t later in the year. Have a roam around the folders and pics at This Site Some of the photos are quite large files. I am at the stage where I have to do all the piston deck heights and machine the crowns to get my desired compression ratio, otherwise the bottom end is pretty much done, and I will be atarting on head porting, chamber balancing, machining cam lobe reliefs et cetera. It's taking a while as I unfortunately have to make a living as well as play with my own engines!
I must bring it down to you once Rod has finished putting the OS box in it and the new brakes are fitted.
(he is also having the wheels powder coated, Iwanted somewhere between the car colour,and black but they have ended up lighter than the car, hmmmmmm. Hope they haven't ended up looking like cheap Halfords alloys :eek: )
1 - 10 of 10 Posts
