+1 mines been on a lot the last few weeksTurn on the aircon!
Correct.I always thought it was because of the transmission tunnel running the entire length of the car making it hot ?
How much did the Russ fellows set you back? I'm considering one but it's not easy as there are so many options.Look at the Russ Fellows Y pipe. In my opinion its the best out there at 75mm. They are hand made and have a lifetime warranty. The drone isn't too bad and it gives nice note.
The A/C controls should help with the temperature inside and the outside will cool down in the winter. :chuckle:
£375 delivered. If you look at them. Its the only one with nice curves in the pipes where they meet it certainly looks to be the most efficient although I'm no expert. It is beautifully made and finished though and great value.How much did the Russ fellows set you back? I'm considering one but it's not easy as there are so many options.
Not a bad price. I've seen plenty of pics and it does look a quality product. The only question is does it sound good, produce more volume but without a lot of drone. This is obviously subjective, so everyone has different views.£375 delivered. If you look at them. Its the only one with nice curves in the pipes where they meet it certainly looks to be the most efficient although I'm no expert. It is beautifully made and finished though and great value.
