Hello everyone,
SpeedForSale is proud to release the first item from our new performance parts brand. We have multiple other items about to be launched as well, so keep an eye out for these over the next couple weeks.
After multiple revisions and tests, we are happy to introduce our new SpeedForSale 102mm (4") Mid-Pipe and Cat-back Exhaust system for the GT-R! This system is priced at only $2800 for BOTH the Mid-pipe and Cat-back exhaust system, and offers options such as a dual resonated or dual catalytic convertor mid-pipe, and mufflered or NON-mufflered cat-back exhaust section.
You can find full details, options, and pictures here on our website:
CLICK HERE! However, please note the video shows the test tips, NOT the actual production tips as shown in the pictures below![/b][/b]
  • Available options included resonated, NON-resonated, or catalytic midpipe, mufflered or NON-mufflered Cat-back, and more.
  • Bolts up to any GT-R downpipes
  • Made in the USA (Atlanta)
  • 304 Stainless steel with high quality TIG welds. Thick gauge stainless steel helps prevent interior drone and resonance, yet the entire system weighs LESS than the stock mid-pipe and cat-back exhaust system!
  • All V-band flanges and connectors except the mid-pipe's front pipes which are the standard 2-bolt flanges to connect to any GT-R downpipes.
  • The mid-pipe has dual 75mm 3" pipes connecting to the downpipes, each with a flex section. These two pipes merge into a massive 102mm 4" single pipe which connects to the Cat-back exhaust section via V-band flanges and connectors for a smooth exhaust flow transition, quick and easy installation/removal, and more ground clearance than a standard 4 bolt flange. The mid-pipe comes standard as NON-resonated, but we also offer optional dual resonators or dual high flow catalytic convertors.
  • The Cat-back exhaust section has a 102mm 4" intermediate pipe which splits out into dual 75mm 3" pipes going to the high quality mufflers. After the mufflers, each pipe splits out again into two more 75mm 3" pipes leading to each exhaust tip.
  • Four 125mm 5" slant cut exhaust tips. They are adjustable in terms of mounting depth and clocking/rotation, so you can choose how far out they stick and which way the slant cut tips are rotated! This means that you can clock them sideways so that they follow the angle/slant of the OEM rear lip of the GT-R just like the stock tips do, or clock them at another angle for a unique look. The outside of the tip is polished, and we also offer optional polishing of the INSIDE of the tip.
Discussion Starter #2
Price lowered!
