1 - 20 of 22 Posts
Hi, I'm going to go through all the manuals / receipts at the weekend. Until I know what I've just brought, lol, can someone tell me what I need to do before and after driving? Stage 1 Cobb etc, temp here's a few degrees over freezing right now. Had some great / some scary moments today, need some advice so the car will still be running on Saturday. (It better not rain).
Ideally;
What temp before moving
What temp before warp drive
What temp before shutdown.
That seems to be my experience today :thumbsup:
Hey Andy, welcome to the club :p
It has been pretty damn cold recently so its quiet important to manage temps well in the GTR.
Basically before moving i usually let mine hit around 25-30 degrees at least on the trans diff oil temp.. Same with engine oil but it usually seems to warm up faster than the trans oil temp.. Moving off at this temp you wanna be easy on the car, let it warm up gradually.. I have also heard that it is not so good to let the car warm up all the way from freezing temps up to normal running temps at a complete standstill.. Its better to drive off at safe temp and let it warm up while moving so that oil can circulate correctly..
Temp before warp drive is ideally like 80 degrees but you can start putting your foot down by 75..
Im pretty sure you can shutdown as long as its under 100 degrees..
Thanks. I can relax (prob. The wrong word);) tomorrow.
That works great, I have 5 mins of 5mph crawling traffic, then the roads open up. Same every day.
I'm loving the car. Unbelievable. Wish I'd done it sooner.
Hi Hash, I have near zero mechanical knowledge so this may well be a daft question, but how does the diff get any heat if you're not moving? Surely it's engine, clutch, transmission, diff?
So how does the diff gain any heat energy dissipated from movement if it's not moving?
Like I said, near zero knowledge so it's probably obvious, just not to me...
Hi DonnyMac and welcome to the club ;) to answer your question: the front diff is fitted to the engine block and the rear is part of the transmission so both get heated up by transmitted heat :).
Cheers chap, makes sense - I've always been of the warm up whilst moving school of thought.
Sub 2.5-3k revs until everything is toasty warm and oil pressure drops - much easier to judge in a car with more gauges than the millennium falcon.
Thanks again.
What about cooling down after a standard motorway drive (70-80 mph) and after a heavy / spirited drive? In the Evo, I was told to drive the last few miles / minutes in top gear at around 1.5k revs (which equates to around 30mph in that car so works well). Is this suitable for the GTR or are there other / better suggestions?
lol thanks Sly, I had no idea how to answer that question :p
I think you only really need to do some cool down laps if you are really driving it hard or launching it, like you would on a track and hit very hot temps (ie: 100+degrees)..
Good info thanks folks, so around 80 before giving it beans?
Banned
Its no different to any other car. Its not a space rocket.
Don't hammer it cold and have some mechanical sympathy for the thing and you'll be fine.
I always warm mine up till 50 C all and then go. I will sometimes put a carton on my oil cooler because, mine does go up with these cold weather.
cool down:
- normal drive 30 secs.
- spirited drive 1-2 minutes
- extreme drive 5-10 minutes
The reason why you don't switch a turbo car off straight away after a hard drive is because the only thing that greases the turbo bearings is oil (switch the car off after a hard drive no oil pressure = no turbo bearing lubrication) the turbo will still spin for a while after a flat out drive at least 3 mins + after a hard drive to allow the impeller to slow down
no, the turbo only spins high speed when you are under boost. it either doesn't spin at idle or will barely spin. the reason people say to idle before shutting off a turbocharged vehicle is to allow oil and water to circulate through the turbo to bring it's temperature down so the oil doesn't coke in the turbo. If you've been driving hard, drive it easy/let it idle for a few minutes before shutting it down.
As above, the turbo's are screaming hot and will bake the stationary oil if switched off after a hard boost.
Turbo timer's though are just a pointless gimmick, no point sitting at idle for 2 minutes and letting everything else heat up.
The sensible method is to just drive off boost for the last few minutes of any drive, letting air flow around and cool everything, including brakes.
Same when setting off, just let everything get up to temp before boosting.
Doesn't spin at idle? Have you seen a turbo at tick over with no pipes on? Put your finger in it the tell me it's barely spinning ;)
Perfect answer, someone with a knowledge of turbos.:thumbsup::D
1 - 20 of 22 Posts
