Hi,
I'm collecting my 2011 GT-R on Saturday and I can't wait! When test driving it last night I noticed a couple of things.
On a constant brake pressure, approx 30% when I was changing down manually into a lower gear, where the revs would rise to approx 4-5k rpm, the smoothness of the engagement into the lower gear wasn't great. Is this normal? I know you can upgrade the software but I'm buying it for a NHPC and don't want to lose the warranty. Do re-learns exist?
The red leather on the edge of the drivers seat is a bit worn. I know this is quite common. Does anyone know of a way to rejuvinate this?
I'm in north London, buying from Mill Hill Nissan, so hopefully see some of you at a GT-R meet soon.
Yes a relearn is possible.
What mode was the gearbox in?
Sod the warranty, I assure you it will be gone in no time.
Where abouts do you live?
Happy to meet up - I'm mill hill based.
I've found that when braking quite mildly (i.e. not pushing on) that it's better to change down a gear at lower revs for smoothness (~2k revs unless changing into 2nd when it tends to be just above 1k revs). I could probably do a re-learn to sort it but when I'm pushing on there's no issue so I'm not too fussed tbh.
Maybe give it a try and see if this helps or else, brake harder :)
Discussion Starter #4
Cheers for the advice. Will ask the garage to do a relearn. I don't have a clue what mode I was in, was enjoying the power too much!!
Adam, I live in Palmers Green so only a few miles away, it would be great to catchup and see your car at some point.
