We are proud to release our new billet fuel tank sender for the R35 GTR, made for us by Xtreme Motorsport.
This hanger is designed to replace the restrictive stock plastic unit but still retain the stock fuel level sensor which clips into place on the hanger.
We found this very beneficial when fitting large fuel systems like the AMS.
Larger fuel pump installs still have to push all the fuel through the small restrictive feed on the top of the hanger. This can cause fuel pressure issues and also heat the fuel unnecessarily.
This product eliminates the restriction and enables the use of different fittings, we have chosen a -8 feed and -6 return as this is most common and will support over 1000hp.
The factory fuel line also carries restrictions and this allows new fuel lines to be run down the car.
The plug provided is aero grade and allows large enough cabling to run twin 044 pumps or similar with no issues.
A must have for any big power GTR
Price is £549 inc vat
These are in stock and ready to go
Lee
Lee
