1 - 11 of 11 Posts
First of all Hi to everyone :wavey:
I,ve just sold my GTS-T and done a deal for an R32 GTR Vspec (been wanting one for ages)
I have a couple of problems i need to resolve and any help would be great!
I knew the car had some issues when i bought it but the lad had lost his job and had no money to fix it so i got it at a good price.
I went to see it last night and before i got there he had moved the car ...so it was running, it was misfiring throughout the rev range!
however the battery was dead, when i say dead he turned it off and it wouldnt even turn it over we had to jump it and it was very very low on fuel!
I got the car home, charged the battery overnight, filled up with optimax
And this morning it starts on all 6 cylinders but when its to temp it starts and drops to 5 cylinders and misfires throughout the rev range.
Any ideas guys?
Any ideas guys?
coilpacks.
Missfires are not uncommon .Spark plugs should be your first check , Coilpacks and Ig amps do fail but not as often (IMHO)
You can check plugs and coilpacks by substition if the problem is on tickover as you can disconnect the coilpacks by unplugging from the spark plug cap in turn.
You can open them but won’t have any luck fixing it. I tried to fix my one but it has gel on it. If you want to open it get a blade cut the grove on the black side of the amp and get a flat head screw driver try to wedge it open
Coilpacks
Out of interest, did you replace all the coilpacks or just the one?
Where did you get the replacement from?
Cheers James
1 - 11 of 11 Posts
