1 - 18 of 18 Posts
Hey guys,
MY GTR is ready for 4 new tyres. I currently have Dunlop RF.
I live on the isle of man it is raining most of the year, yet we have no speed limit and bumpy/bad roads.
Should I just get another set of run flats in the same size or are the MPSS genuinely better ? also what would be the best size for me ?
I could do with a little put of a more comfy ride as mine is 2009 and the soft button doesn't really make it soft.
Also having a puncture/tyre blow out wouldn't be a huge issue for me as the island is small, so getting it sorted and getting home is easy.
Again, please be honest as I just want the best for my car.
I think MPSS is the answer for you. Much softer then the Dunlops but with little compromise... better handling in the wet too.
Im running the oem sizes but a lot of people run a square set up which Litchfield recommend.
MPSS for you unless you plan on taking the car on track.
Does litcho recommend a square setup, I always thought it was 275/305 as I have on mine???
R35 Section manager
Never tried anything else but Bridgestones so it would be unfair to comment but I think I will either be looking at Mpss or Toyos on the next change.
MPSS from what you have said. You could consider the MPSC (cup version) as this might be in between.
If your roads are bumpy I wouldn't recommend the bridgies as they do tram line a bit on minor roads which can unnerve some.
Discussion Starter · #8 ·
ok, so looking like MPSS could be the ones for me, I have 20" Volks Racing G2 wheels fitted. At present I am running standard 255/285 Dunlop RF setup. So what would be best ? 275/305 or what is the square setup ?, basically want it to handle like it's on rails, especially in wet conditions.
I've got 275/305 stance, and I've found compared to bridgestones, the mpss keep the tail firmer to the ground, which I prefer.. less twitchy, which enables me to play more.
If you don't have big ambitions, I'll fit the car with the MPSS, cheaper than Dunlop, but no track at all as they're awful:wavey::wavey:
The square set up is the standard 285 rear tyre size all round and what I am considering when I next change.
Litchfield recomend the 275/305 set up. Jonny at JCR has been trialling trials and whilst hasnt formally said it, he did seem keen on the MPSC in 285/295 sizing.
I've tried the 285 setup after buying my car with Dunlops which were shot. I found the ride a bit too squidgy for me, I then switched to 275/305 which were less squidgy and offered quite a bit more grip.
Both setups were a lot less harsh than the dunlops. I have also tried the Toyo 888's, grip was awesome but they were far too noisy.
Have the 285's sat on a pallet with 5.5 mm tired depth I'll let go cheap if your unsure exactly what to go for.
How much for your 285? And what are they ?
Discussion Starter · #15 ·
Thanks for the offer mate, but after reading on here I have decided to go MPSS and 275/305 setup.
Getting them fitted friday morning. So will update you guys on what I notice.
How much did they cost?
Hey guys,
the best tires for all conditions in my opinion are the mpss at present running 275/35/20 at front and 305/30/20 to rear. only got 7k miles from Dunlop run flats. only problem on a wet night with a flat tire don't know will I still be happy,,,,,,,
1 - 18 of 18 Posts
