First off, just registered as I am now the new owner of Trial tuning Spirits R32 GTS-t RB24T demo car.
Names Martin, from Ireland. Previously owned an AE86 track car until my move to skyline. Have not yet taken delivery untill next week, monday so wil have more photos etc.
Here is the spec:
1993 (latest of the R32's)
ENGINE & MANAGEMENT:
Trial RB20 engine with Tomei 2.4 Stroker kit (RB24T)
Trial TUNED ROM CPU/ nissan ECU
Tomei Forged Piston/ring kit
Nismo Timing Belt
Nismo Injectors
HKS GT2530 Turbo kit
HKS Racing plugs
HKS Racing leads
HKS Oil Cooler
HKS Boost controller EVC3
HKS SQV Blow-off valve
HKS EIDS (TYPE-H1) Electronic Idling Stablizer
HKS Power Flow Intake
HKS Camshaft IN&EX (264Deg)
HKS Campulley Kit
Blitz Racing Radiator Cap
SARD Catch tank
Apexi Intercooler SRS
Apexi Super Catalyst
Earthing kit
POLISH TO VALVE
BIG CAPACITY AIR FLOW/M
AIR COND COMPRESSOR ASSY
REINFORCE ACTUATOR
EXTENSION KIT
FRONT PIPE
CATALYST ADAPTOR
240 L/H FUEL PUMP
Engine down
SIM Adjustment
Valve Timing Adjustment
Cylinder Boring
Cylinder Horning
Polish to cylinder Block
Polish to Cylinder Head
Adjustment to metal
Tomei 82mm Piston kit
HKS Metal head gasket
N1 Water Pump
Nismo Oil Pump
Blitz upper hoses
APP Brake hose
Trial Bazooka Exhaust
Suspension & Drivetrain
HKS coilover kit
Nismo ARM Tranbars link
Nismo ARM Front Upper Link
Nismo ARM Rear A Arm
Nismo ARM Rear Upper Link FRONT
Nismo ARM Rear Upper Link REAR
Cusco PIRO Tension Rod
Cusco Hicas Lock Cylinder
Cusco Stablizer
Nismo reinforced engine mount
nismo reinforced transmission mount
Fully spot welded
Cusco Carbon Tower Bar
ORC Ogura Clutch triple plate ORC-709-01N
Clutch Master Cylinder
Gearbox Assy
Top Fuel Super Release Fork
OS Giken Super Lock LSD SPL Type
Brakes, Wheels & Tyres:
Brembo Brake System F40
Quantum RS Street F/10k R/8k
Brembo Brake disc 340mm
Brembo brake system rear
17” WORK Emotion CR KAI Alloy wheels
Yokohama ADVAN NEOVA Tyres
Inside & Outside:
Alpine rear speakers
Omori Oil Pressure Gauge
Omori Oil Temp Gauge
Omori Water Temp Gauge
Joint Adaptor
Razo Turbo Timer
BeeR Rev limiter
Racing s/Wheel & Shifter
Recaro Interior
Trial front aero kit
Trial Rear Aero Kit
Trial Skirt kit
Trial spoiler
HID Headlights
And a few photos;
Here is the spec:
Nismo Timing Belt
Nismo Injectors
HKS Racing plugs
HKS Racing leads
HKS Oil Cooler
HKS Campulley Kit
SARD Catch tank
Earthing kit
POLISH TO VALVE
REINFORCE ACTUATOR
EXTENSION KIT
FRONT PIPE
CATALYST ADAPTOR
240 L/H FUEL PUMP
Engine down
SIM Adjustment
Cylinder Boring
Cylinder Horning
Adjustment to metal
N1 Water Pump
Nismo Oil Pump
Blitz upper hoses
APP Brake hose
HKS coilover kit
Cusco Stablizer
Fully spot welded
Gearbox Assy
Inside & Outside:
Joint Adaptor
Razo Turbo Timer
BeeR Rev limiter
Recaro Interior
Trial Rear Aero Kit
Trial Skirt kit
Trial spoiler
HID Headlights
And a few photos;
