Happy New Year!!
To kick off a great 2010 I've decided to do a killer deal on RIPS genuine RB30 1000+hp rated short blocks.
As you know, we have had huge success with our RB30s, they have been tested well beyond the power levels most of you would ever need, we set world records last year in the 240z (7.86 on the 1/4 mile), NZ records first time out in our drag car (currently best of 7.41 on the 1/4 mile) and Jeffs Drag-r has shown brute power with reliability over the last 18 months or so, now being the quickest and probably the heaviest full street GTR in the world with a 9.46 on the 1/4 mile.
Everything we have tested and proven reliable goes into every engine built here at RIPS, we guarantee quality Workmanship, Parts, Machining and Assembly and back that with a 12 month RIPS WPMA warranty. (Workmanship, Parts, Machining and Assembly)
I'm taking orders for our forged 2wd/4wd RB30 shortblock which uses the EXACT same combination as our world record holding RB30 which was in the 240z and is now in the dragster.
We have run aprox 1400hp and at times 9500rpm+ for nearly 2 years, the engine is still going strong now and we are chasing 6s with this street spec bottom end.
RIPS RB30 forged shortblock consistes of:
Carefully selected genuine RB30 block which is stripped to a totally bare block, its acid dipped in a very specialised tank far superior to most.
It receives RIPS block mods which include but are not limited to enabling the use of a TOMEI oil pump and 2wd or 4wd applications, its bored, honed and decked and cleaned to the highest possible standards before assembly.
It receives top quality forged pistons with top quality rings, top quality billet rods (all identicle to the world record engine)
It receives custom RIPS crank modifications to the genuine RB30 crank, its gets a wide oil pump drive, grinding and balancing to perfection and ACL race bearings.
It receives all new brass frost plugs, new oil gallery plugs, oil restrictor/s to suit your application, blueprinting and assembly in probably one of the cleanest engine rooms RB engines are ever assembled in.
You also receive the correct cam belt for running a RB25 or RB26 head.
nzd9995 INCLUDING shipping by sea to your nearest sea port.
Group buy of 3 units, deduct nzd750 per unit, group buy of 5 units, deduct nzd1000 per unit, group buy of 10 units deduct nzd1500 per unit.
Here is one shown with Tomei oil pump (optional extra)
Complete bottom ends (including oil pump, big sump, 1500hp front damper etc) or complete engines also available at great prices.
Rotorua Import Pro Shop R.I.P.S
e-mail [email protected]
Rob
Rob
