Hi all,
I am new to this forum and have just purchased a 91 Pulsar GTi-R after owning a heavily modded S13 200SX for the past 3 years.
The pulsar I bought has had Hiteq's Stage 1 Tune and has an HKS Paddle Clutch fitted as well.
I have a couple of questions peeps:
What power should I be expecting, I have a RR printout of 316BHP.
Do all R's have such a short throw gearbox? I don't think that it has a short shift kit cause the gear stick is still the standard height. Could it be an uprated box?
When I pull away sharply in 1st and if i drag the clutch on a fast gearchange I can hear a whine/crunch noise which is also felt a vibration through the clutch pedal. Any ideas on what this is?
Graham.
gti-r
hello
nice choice of car mate do you miss the 200?
not sure if it helps on the clutch side check the pedal box inside the car had similar noise when changing gear (running a ap as well) then the pedal box broke away from the bulk head!!
made sum brakets up and was sorted (didn't fancy taking dash out and welding etc)
might help not sure mind
tony
