Seeing as I can't make a decison on what mod to do next I'm leaving it up to you.
the choice is between exhaust and better FMIC, the car is an R33 GTSt with a HKS 3037 and supporting mods (304bhp ATW)
1. Current FMIC has a core size of 380mm x 220 mm (bar and plate) the replacement (from a known good source) has a core size of 600mm x 300mm (Bar and Plate) with 76mm inlets and suitable piping.
2. Exhaust is currently a NUR spec backbox with custom 2.5" Straight through centre section from the de-cat back, the replacement will be a minimum of 3.5" with at least 1 silencer.
cost is not an issue as I have funds for either but not both.
you decide - you have 24 hrs
Simon
Simon
