1 - 6 of 6 Posts
Hi, I bought a bottle of NF octane booster. Should I put the whole bottle (300ml) with a full tank?
What is your target octane? Why are you using it? I dont think i bottle to a full tank will achieve full potential.
Google is your friend:
NF Octane Booster Racing Formula is the top of the range Octane Booster and the best you can buy. The superior fuel treatment is used for a super high performance.
For high compression and performance engines
Increases Power and Performance
Increases of up to 6 RON
One Bottle treats up to 6 tanks
Valve seat recession protection
Nitrous Formula has been tried and tested and is without doubt the best Octane Boost on the market
Supplement for leaded fuels
As used by CAM Auto Developments and the majority of their customers
Wanting more Power and Performance? Wanting better fuel economy? Or just a smoother running engine?
Not only can it be used for a super high performance octane booster but doubles as a very economical everyday use formula for valve seat protection.
Nitrous Formula Race has such a wide market, it is having exceptional results with as little as 0.25 mls per litre, with Extrodinary results and performance increases on very high compression engines which are using upto 15 mls per litre. You choose what performance you want and what suits your engine best. For valve seat protection this bottle treats upto 300 litres of fuel. This super high performance octane booster will increase the octane level by as much as 60 pts or 6 Ron
That sounds like a load of BS. The Klotz Higher Octane Booster I favour claims to add upto 10 RON Numbers when an American pint is added to around 15 litres of fuel.
I usually recommend 1 bottle to 30 litres for a circa 5 point gain. Or if just safeguarding against shite fuel then 1 bottle to a tank would give a couple of numbers rise.
The concentration levels of that sound bonkers. I'd be looking at the ingredients and checking what's in there
1 - 6 of 6 Posts
