Configuring larger injectors into the PowerFC is quiet simple and takes only a few moments. You need to know the following information before you can continue
Current injector size
Current injector latency
New injector Size
New injector Lag time
Injector Size and Latency (standard units)
Unit Size Latency
RB26 444cc/min 0.772msec
RB25 370cc/min 0.528msec
SR20 (Jap Spec Manual) 448cc/min 0.584msec
Aftermarket New Units 600cc/min 0.810msec
To work out new INJECTOR correction and latency;
Old SIZE / New Size = Correction
Old Latency - New Latency = Latency Correction
John plans to install 600cc injectors into his RB26 VL Turbo. The following figure's are used;
444 / 600 = 0.74 * 100 = 74.0%
0.81 - 0.77 = +0.04 msec
So he would enter 74% for correction and 0.04 as new latency
Once you have switched to larger injectors you should still check your AFR's with a wideband to ensure they are safe and acceptable.
From >
Apexi PowerFC FAQ or
Paul's Homepage
:thumbsup:
