:)Need bit of advice, just installing my Nismo rear arms and need to know when I torque up the bolts do you have to have the suspension level at a certain position when you finally do them up.
I.E level in the middle or dropped low as it sits unloaded without the wheels or compressed to mimic a loaded situation?
Appreciate your input ***128526;***128526;***128526;
Marl
When ever I've tightened a suspension bush bolt I have the suspension arm where it is when the cars on the ground. Otherwise the rubber within the bush is twisted. I'm on the understanding that with poly bushes, you don't need to do this.
Thanks MS33 ,
That is my understanding as well, the manual said torque when car is on the ground, can’t get my frame under there it’s too low!!!
Thanks again for the reply , I’m still a bit bemused on how the inner sleeve of the bush moves with suspension travel without tearing itself free on the rubber ?
Heyho ***129299;
