What makes the Nismo suspension pieces "better" than stock? Ive been wanting to start purchasing the pieces but thought i would look into it before i just went randomly buying parts.
Lighter?
Stronger?
or just better bushings?
Nismo also makes avail the z-tune spec rear upper arms that reduce neg camber for lowered 33 and 34 GTR's (5mm longer than stock). Not too expensive, either.
I am hoping they will release something similar for the front!
For the 32 all the arms are the same as standard with uprated Nismo bushings (which are available separately). The only exception is the circuit link kit which has lower arms with repitched holes to increase negative camber. (Midori and Autoselect sell similar arms). The upper brackets in the circuit link kit are also about 50% thicker gauge - a useful improvement on the slightly compromised R32 upper wishbone design.
