I have a set of white Nimso centre dials for an R33. I replaced the stock ones which only read to max 700mmHG (0.93 bar eqv) whereas the Nismos read to around 1.4 kg/cm2 which is just under 1.4bar. Now when I run the standard gauges I was showing just under 1 bar boost (expected) whereas with the white dials are showing around 1.4bar. My question therefore is are the boost sensors different as they both show the same physical position on the gauges but obviously one is considerably higher than the other.
Thanks!
Thanks!
