Does installing the nismo clocks remove the 180km/h limit? Anyone know where i can find new r34 nismo clocks and what it might cost to ship to Suriname? I'm also installing the pfc d'jethro, so the limit will anyway be removed but i also would like to know how fast i'm actually going without getting any aftermarket gadgets.
You mean the Nismo gauge cluster, no the nismo one will not remove the speed limiter as it is the factory ecu which governs your speed not the gauge.
Your car will still be limited to 175km/h or 180 at the most.
Once you get the aftermarket ecu, the speed limiter will be removed.
I can have a Nismo gauge cluster sent from Australia. Let me know if you are interested.
