1 - 13 of 13 Posts
we have just supplied one of these RB engines.
not sure if anyone else wants one but can ship pretty cheap via container to the UK
They are on a limited run.
Nismo Final Spec RB Engines made at Omori
Not a bad price delivered to the uk , if the spec is more refined than the N1 , and can take a bit more boost . If I remember right it was nearly £5g for an N1 in Japan , might be wrong
Specifications-
- N1 Cylinder block
- N1 Component / nur spec pistons
- N1 Component precise friction piston rings
- Nur spec connecting rods (Balanced)
- Nismo F112 connecting rod bearings
- Nismo F112 main bearings
- Standard spec camshaft
- N1 water pump
- N1 oil pump
- Nismo timing belt
- Nismo metal head gasket (1.2mm)
- Nismo oil pan baffle plate
- Nismo fine spec 2009 special edition rocker cover ornament
- Exclusive fine spec 2009 special edition engine plate
- Front differential (Gear ratio 4.11)
- Black cylinder head covers
Tbh , it's not a bad price for a long engine . If that's the spec bearing in mind the front diff and all included but the N1 oil pump is going to kill it for most that want to push the 26 / if that's the spec
1 - 13 of 13 Posts
