Which would you go for? I plan to have a custom made 3.4L stroker kit from crower (if possible) The Nismo GT block is stronger than the N1 block...I need so help
Hey kismetcapitan...you are in freshalloy.com forums also huh? Yes he tells me that I need to make more power to beat the JZA80 supra in a race. I will just see once I get mine to where I want it. I am looking for well over 1225hp+ with the parts I am having put on the car. Everything internal and some external parts will be heat protected and far better in every way when it came from the factory. So I am sure it will be faster than his car...I just havent told him about EVERYTHING I am doing to the car heheyour friend is talking a lot of trash about how great and amazing Supras are - they suck
I don't care how much power a Supras making - race him from a dead start or on a circuit with a GTR and you'll own him.
Ok my list is this so far..I cant list everything from the top of my head but this what I am looking for right now.
2002 Nissan Skyline R34 GT-R Mspec Nur project
Nismo GT500 spec Block swap
Custom stroker (haven't fully decided yet)
Twin T04Z .81 A/R
Twin GT2 60mm wastegates- Why? Are you planning on running low boost constantly? If not you should stay with 40-46mm gates.
HKS evc pro silver edition
HKS fcon vpro stand alone
HKS V-CAM 272 degree IN
HKS step 2 EX 272
Twin blitz SUS power filters
HKS racing blow off valve 2
Nismo Z tune intercooler- Will not support the numbers you are looking for.
HKS s type oil cooler
PWR radiator
Sard cooling thermostat
HKS timing beat
HKS EX cam gear
HKS heavy duty valve springs
JUN titanium retainers
HKS racing titanium 4.01in exhaust- you should go for a larger dia size if you are looking for quicker spool 4" will not flow out quick enough for twin T04Z.
Nismo motor and transmission mounts
Tomei oversized oil pan and nismo baffle plate
Mines triple flow cam cover plate
HPI engine torque damper
Twin HKS exhaust manifolds- HKS does not make a twin manifold for T4 Manifolds, it has to be custom
triple Walbro fuel pumps- Why? You might as well something more that will flow more than Walbros
Tomei oversized oil pump
ATS carbon triple plate clutch
HKS fuel rails and RC engineering 1600cc fuel injectors- If you are looking to have the car daily driven I'd recommend dual rails with 800cc and 1000cc injectors for your 1,300whp goals
Naprec valves
Tomei valve guides
HKS twin power ignition system
JUN GT intake manifold
top secret 100mm throttle body
ARC 2 in 1 oil catch tank
Nismo slave cylinder
Trust ACPT carbon fiber driveshaft rated at 16,000rpm
Nagisa auto fender braces
Ohlins flag R suspension
Nagisa auto full pyro (tension rods, lower arms etc)
AP racing front 6 piston big brake strap drive disk
AP racing rear 4 piston
Nismo suspension refreshment (bushings etc)
Nismo roll bars
Nismo Z tune rear member brace set
HKS AF knock monitor
Elecktra carbon fiber trunk and doors
Mine's carbon fiber 50mm taller when and mirrors
Nismo Rtune carbon fiber bonnet
Sparco S light carbon fiber seats
HPI carbon door windows
Nismo Z tune front bumper
Nismo full body kit
Nismo LMGT4 18x9.5
Flaken RT-615 275/35R/18
