I want to put one in my R32. Being DIN-sized, it can be made to fit, but I'm wondering about the senders - will it work with the stock wiring (R32 oil temp sender wiring into the R33 oil temp gauge, same with boost). Also, where might I find the front torque sender/sender wiring? The main reason I'm considering this swap is that with my ideal seating position, I can't see the damn front torque gauge as it's blocked by the steering wheel, and as I don't need voltage, I could definitely use the front torque gauge in that position. Can't see the fuel gauge either but that's a good thing - horrific amounts of gas this car drinks, yes it does.
