You need the crank girdle in place and torqued up. Only then can you establish if it is distorted or not.
The girdle is a tight fit within the block, and the torque applied to the block from the bolts that hold the girdle in place will very slightly change the shape of the block, so to establish whether it is distorted or not you need the crank girdle in place.
