1 - 10 of 10 Posts
Administrator
guys,
ive got some genuine R33 GTR Nismo rear spats.
I've had them sprayed off the car and now want to fit them
they appear to have had been held on with some sort of glue before, despite 3 screw holes.
has anyone fitted these themselves, if so, did you use sikalex or similar, or double sided sticky pads?
any input?
thanks
mook
guys,
any input?
thanks
mook
Mine were held on with a strip if double sided trim tape aswell as the three screws.
Administrator
did i buy them off you?
:shy:
Cos i did see some sort of tape on there but didn't know what it was.
could i use the really sticky pads that you use to hold on number plates do you think?
mook
spats
hi i started to use double sided tape but in the summer it sagged so i used good old sikaflex only problem if you evre have to remove them:bawling:
sikaflex is very strong, best of luck.;)
i wouldnt recomend sticky tape. Used to have the spats on my supra held on using sticky tape and screws until one high speed blast caused one of them to be ripped off. Id use Tigerseal and screws, i learnt the expensive way.
1 - 10 of 10 Posts
