1 - 7 of 7 Posts
To save me doing a search on this subject - Can anyone tell me if the boot badge can be easily removed - is it just stuck on or will it leave holes if i remove it etc??? If it can be removed easily and is just stuck on - any tips to remove it without damaging the paint??? Thanks!!
Hot water from the kettle can also be used to heat glue like this to soften, with no danger of over doing it and bubbling paint etc. which can be an issue with heat guns.
Aslong as you don't put the hair dryer on full, and have it mm's away from the paint, i'd presume he would be alright ?
debadged my M3 a few years back remember to pull the badge away from the car evenley or like me if you raise one edge too far the other edge marks the paint
Thanks for tips guys - just boiled the kettle and gently lifted it off - came off no problem and looks so much better and cleaner now!!
1 - 7 of 7 Posts
