My Nissan R34 GTR is going up for sale,
The car has just undergone a full under body restoration.
here is spec of the car
This is the spec for that one
Engine system
HKS 2.8 STEP ZERO
NAPREC Hirespons Kit
Forged IN valve Valve guide for race EX valve face polishing Sheet cut (protruding)
Head surface laboratory
JUN IN 264 ° 9.1 lift EX 264 ° 9.1 lift
Head Gasket Kit Cam sprocket
APEX V-MAX Valve Spring
Turbo HKS To4'Z Full Turbine Kit
Intake system
RWR air cleaner Original suction pipe
I / C piping
Exhaust system
Tomei extension
HKS stainless steel F pipe
Metal catalyzer
Trust Ti-R 80
Cooling system
HKS intercooler R type TRUST Aluminum radiator
SAMCO radiator hose
HKS OIL cooler
Billion Low Temp Thermo
Ignition system
Nissan R35GTR genuine ignition coil
HKS M40
Fuel system
RH-9 F pump 255L SARD
650cc Low Resistance TOP 2 Injector
Control system
HKS F-conVpro Vr3.24 D JETRO specifications
F-con harness
EVC6
Drive system
ATS carbon twin plate clutch
Suspension
OHLINS STD Short Model
Wheel RAYS CE28N 18 × 9.5J + 1
Brake ORC 6pot 355 rotor
Ferodo rear pad
looking for £135,000
Wheel Land vehicle Car Tire Vehicle
Vehicle Automotive lighting Automotive tire Motor vehicle Automotive design
Automotive fuel system Automotive tire Vehicle Automotive lighting Motor vehicle
Wood Electrical wiring Electricity Gas Cable
Tire Wheel Automotive tire Automotive lighting Tread
Motor vehicle Automotive tire Hood Tread Automotive design
Automotive fuel system Vehicle Automotive tire Motor vehicle Automotive design
Motor vehicle Automotive tire Automotive design Automotive wheel system Automotive exterior
Motor vehicle Automotive tire Automotive fuel system Automotive design Hood
Tire Wheel Vehicle Land vehicle Car
