1 - 9 of 9 Posts
Has any bought the r34 nismo led lights?
Just bought some last week and just wanted to know if everyone had this issue:
The indicator lights flash very quick as if a bulb is out?
Thanks, any response would be appreciated.
I've not got them but because they are LEDs they will have less load, so I would expect them to need a resister so that they match the same load as a bulb. Then they will flash at the correct speed.
Hope that helps.
Discussion Starter #4
Hi, just the rear tail lights and rear indicator lights are led. The side lights are normal bulbs.
How do i connect the resistor?
Well, I would measure the resistance of a normal bulb. Then get a resistor of the correct value, cut the wire that feeds the light cluster for the indicator power and then solder the resistor inline with the wire. This would have to be done on both rear indicators.
I would have thought Nismo would have provided all necessary resistors on their lights. Is it a genuine Nismo light?
Do you have any pictures of them?
I bought a set of the nismo led tailights and have been getting the same problem. It happens on an off, on the left side only. The front left indicator flashes quickly and when brakes is applied, the rear tail lights blink.
1 - 9 of 9 Posts
