Hi,
Like the title says, the 4WD, hicas, abs and check engine dash lights are on. The car only pulls on the rear wheels for sure.
I tried searcing for similar problems and found this thread;
http://www.gtr.co.uk/forum/120660-abs-4wd-dash-lights-coming.html
Found some possible sources for the first mentioned problem here. But this is not the end of my problem. The only dash units working are the speedo, oil pressure, water temp and fuel level. The most anoying problem is the tach meter not working.
When I bought the car it was not driveable because the previous owner mounted the cams wrong, so that all the exhaust valves where bent.
Now the car has new valves, valve springs, pistons, rods, T-78 turbo kit, Apexi power fc pluss supporting mods.
