The previous owner in japan seems to have disabled my cel and I can't figure out how to fix the issue. I get nothing when I turn the ignition on. Only when I start the car. Checked the bulb in the cluster, it's fine. Checked continuity from the bulb trace to the ecu and that's fine. #32 orange black wire. The ecu seems to not be sending a signal to the bulb with the ignition on. Tried activating the codes via the consult plug and that doesn't get it to light up either. On a side note, I can't get my laptop to connect to the ecu either. Using datascan. I am literally at a loss.
262733
Discussion Starter #2
Also note this happens with a mines ecu as well as a stock ecu.
