21 - 40 of 48 Posts
Hi Andy this is a shocking story ! I notice that you are london based and would like to know which dealer this is with , pm if you prefer to keep them anonymous. Good luck with your situation and i really hope you get it sorted. Such an egregious error from the dealer to forget to fill with engine oil !
I would want a new engine including turbos, and I would probably sue them to get it depending on the legal advice and expert reports received.
My GT-R was on the alignment bed at Westway Nissan in Oxford. In another bay, I saw a VW (Golf or Polo) being worked on. The guy poored oil into the engine through the oil filler, and then got in the car and started it up. After about 20 or 30 seconds, a loud shout went around the workshop, with everyone walking towards the VW and pointing frantically to the underside of the vehicle, and trying to get the guy who was sat in it's attention. All the oil was on the workshop floor, because he hadn't replaced the drain plug. He replaced the drain plug, put some more oil in the engine, and started it again. The owner will never know. NHPC? Nissan Hopelessly Pathetic Criminals.
I've often taken previous cars to a local garage and they let me hang round whilst they do the work. I much prefer this and it helps build up trust, and they get my repeat custom. The whole health and saftey quote is bull, insist that you see them pull the drain plug. If they dont let you, get them to write a waiver to let you see them working on the car.
Just read this, its absolutely shocking...I would insist they have an independent check everything...I dare say the bearings will more than likely been worn if there wasn't any oil and the turbo cartridge has also been run dry... Ok maybe no boost was applied but still no oil is a serious issue, even if it was just idled
I would insist they replace the engine and turbos...
I would also be there when they start take everything off and video how much oil comes out the drain plug....just to prove there was none in there...all this angle on the flatbed shite there giving it...take the oil filter as its rightfully yours....
Simply demand a new engine and turbos, and do raise a side issue with Nissan UK if you can get pressure from them, I would also line up some lawyer too, they will advise on what proof you need to stand up in court, unfortunately you need to think of the worst case...
Don't listen to this health and safety bullshit, you need to video the car when they remove the sump plug that will prove what oil was in there, if any....this is fundamental if you need to go legal tell the. not to touch the car until you and your legal representative are there....the problem is they will have probably now filled the car with oil...
hope you get it all sorted mate, absolutely shocking...
If it were me id name and shame these baboons publicly....but in the interests of keeping any discussions with a third party that may need to go to court, best keeping it anonymous for the time being
Trouble is if they have the car very easy for them to add oil. I would have gone with the transporter and filmed them opening sump plug.
This is indeed shocking by HPC standards. How can someone forget to refill the oil after an oil change ???
Nissan Westway Oxford HPC are a complete shower of shit and are to be avoided by everyone at all costs!
if the oil level was so low to cause damage the low oil pressure light would of lit up.
The low oil pressure light would be red. I dont know on the GTR but once it has been activated on some cars it stays lit up until you turn the engine off even if the engine has regained oil pressure.
Basically if no red oil light was on then you are o.k.
However, who knows if it was on when they was driving the car on back of the truck? You would hope that who ever was loading the car would of noticed it but obviously not.
I can only presume that nissan pump the oil in, some garages have a pump that you set the amount of litres and it fills the engine. If they set wrong amount then maybe only 2 litres etc was pumped in before it cut out. Very bad practice that they never actually used the dip stick to check or worse case used the cars own sensor. Makes you wonder what else gets forgotten on these services.
Personally i wont use dealers. I would use a specialist like MGT Racing , SVM, Rk Tuning etc.
Crikey. I just saw this. It's just so amateur and sums up the whole NHPC experience. With any luck the engine cuts off with v. low oil pressure so it may be ok but don't know if the R35 does this. Hopefully doesn't get to this but requesting new engine and turbos I imagine would need proof of damage.
21 - 40 of 48 Posts
