The oil pressure gauge has dropped to 0 with the red light on. There is plenty of oil in the engine and prior to it dropping like a stone, literaly! the oil pressure was good. Oil temp and water temp are ok, no leaks , no strange noises, So im guessing no mechanical failure. Searching showed up that the senders are prone to failure however with me just getting the car Im looking for some reasureance that Ive not bust it big time.
I did bounce it off the limiter briefly but cannot see a connection.
What do you guys think, a sender failure? broken wire\loose connection, Any trouble shooting\advice greatfully rec'd. TIA Kevin
