***andy5211 said:changed inlet manifold gasket on R32, now NO spart to the plugs..is there any reset .. didn't disconect the battery...undid plugs, and put them back again...any ideas?
There are fuses to the right of the steering wheel (low down). Not sure if they could cause the problem though.andy5211 said:Powered up the coil packs and it started..sounds like fuse..checked them all ...they are OK
Is there a relay under the dash that could have been affected?
