41 - 50 of 50 Posts
JAE
Ever thought of a long weekend in the English countryside? If you fancy coming to JAE it lasts from Friday night all through until Sunday evening. As far as location is concerned it's only about an hour from Harwich. :)
Hey, looks good. What sort of times are you aiming for?
Our heavy road car just wouldn't go under 10.20 with a stock box. we took 100hp out of the motor (left it at 750hp) to run reliable 10.30-10.40s. The power is easy, getting it down in 3rd is not, good luck with your project, looks very nice :) ....Rob
Discussion Starter #46
So you did 750 with the stock gearbox? And that was at the crank? No uprated gears or anything?
I recon the car will weiging around 1300kg, and that should make us a little bit faster. If you car was in stock trim.
What kind of transmission oil do you use?
Yeah, car weighs 1550kg, we ran 750hp with totally stock internals, NO modifications, standard gearbox using shockproof medium oil. As soon as we wound the power up it just ripped 3rd gear to bits.......Robbie
Discussion Starter #49
Greddy radiator
Greddy oilcoolerkit
Grex Pistons and conrods
More pics of the T88 38 GK turbo
41 - 50 of 50 Posts
