1 - 6 of 6 Posts
As above really what size is the special socket I need to remove them?
Also what torque setting does it go in at?
Skyline Section Manager
17mm 1/2 drive deep socket from Halfords will do it. Grind a slot down the side for the cable and your done.
Nice solution I like it! Prob much cheaper than the purpose made ones! Thanks for the info.
Ps mine seem much larger than 17mm. I tried a spanner at an angle to get the size and it wouldn't go. Biggest I had was a 19mm and that didn't fit either.
1 - 6 of 6 Posts
