1 - 8 of 8 Posts
Hi All
Since getting the car i have been putting some octane booster in my car with every tank of fuel just to be on the safe side until it is properly mapped over here.
just wondering since ive used the lot i had (cheap Nitrox stuff from Motorworld) is there any in particular you would use and where from.
cheers
Craig
Luffy said:
anyone tried the Millers CVL Turbo stuff, seems good but not cheap.
OK to use the turbo if you don't have a CAT otherwise it will fcuk it up. I use the CVL Plus as I still have a cat and it works fine and is cheaper :) .
The STP stuff worked great also.
I use millers cvl turbo but only used 1 bottle before my turbo and clutch went kaput:( so i cant really give an opinion
I've used all of these types in the past and would use any of them again.
I don't use it when on the road, optimax is all you need. If I'm at a RWYB or trackday, them I'll use a booster of some sort.
I used the millers for racing a few years back and never had any issues with it.
Discussion Starter #8
i only use it on the road because the car has not been properly mapped for UK fuel as far as i know. so until it is ive just been adding octane boost to be on the safe side.
1 - 8 of 8 Posts
